Cleaning and brightening teak , and other wood
Momac
7 Feb 2008
UK
I intend to try cleaning and brightening some Teak and possibly some other types of wood. Okay I know you can buy products specifically to do this but they seem a little expensive . I have some garden furniture and a couple of garden sheds to use experimentally. The teak on the boat can wait.
I am thinking Caustic Soda as stage 1
Followed by Citric acid as stage 2
What I don't know is how much to dilute the raw ingredients with water.
Any thoughts?
If you want " New Yellow looking Teak" which is high maintenance there are plenty of cleaners on the market.
On your boat be careful what you use a lot of the chemical cleaners are very aggressive and also a lot of work to keep it looking good.
If you want silver low maintenance to kill all slime and algae and keep cleaning to the occasional wash off, I use Boracol on my deck , boat canopies, teak garden furniture and roof of wifes Fiat 500 convertible. its a biocide, 2 coats let it soak in and a fresh coat every 6 months.
I have a simlar task to complete. It looks like previous owner may have put varnish on the teak deck. Its very dirty and black in some places, and very patchy. Some suggest lightly sanding it, but not convinced its the best option
Products, Advice from Teak Decking Systems
This is the company that supplies the caulking - SIS440 - that JFM has used on MatchII.
I used also SIS440 when I laid a new deck using their FE-180A epoxy system.
Here is an abridged PDF (300kb) containing their range of cleaning products (which the OP is probably not interested in) but more relevantly their advice on cleaning /maintaining teak. See the page headed 'Caution'.
https://dl.dropboxusercontent.com/u/63972157/Teak%20Decking%20Systems%20-%20Teak%20Maintenance.pdf
They lay teak decks on superyachts so know their stuff although, of course, they will be promoting their own products.
Hope this helps
I have personally used quite a few of the proprietary products on the market, ie the usual cleaner & renovator package. Beginning this season I had the boat hull, topsides etc cleaned/polished by the boat yard which,incidentally, is in Spain.It`s a Targa 34 by the way. I also wanted the teak spruced up. The teak was actually done when the boat was back on its berth.So from friends in the marina who saw the guy doing it they said he did work very hard, ie a lot of elbow grease. I asked the guy who did it what he used. Soap powder! Wet the teak, sprinkle the powder, and scrub, wash off. Brilliant finish and have kept up to it with the same every few weeks.
Any thoughts?
When I bought my 760 this year somebody had varnished the teak sides and steps,
Then were very rough to touch a going black in places,
I sanded them down and put about 6 coats of Danish oil on with a cloth very happy with the result and I now just give a light wipe once a month with the Danish oil cloth I keep in a sealed bag
I think it's fair to say you have to be cautious! Some teak decking is just a veneer particularly on newer boats and I have seen many a diving platform showing signs of too much sanding with the base wood showing through the teak! It then looks awful! I've been boating over 30 years and the general consensus seems to be leave it that lovely silver colour teak naturally goes, lot less work as well! :)
Any thoughts?
For the boat, I can do no more than offer you the advice given by tcm many years ago.....
WESSEX 2 PART TEAK CLEANER - METHOD
You'll sometimes see brand-new looking decks at some boat shows that are actually selling secondhand boats. Your teak deck can look like that again. Here’s how to do it.
My own background is having swankyish boats in the med, built/maintained three teak patios outside houses one of them 200 square metres, employed various “experts” and skippers, and spent £hundreds on all sorts of jetwashers, brushes, gizmos, and chemicals.
1. First decide if you want your teak to look like teak - or teak covered with something else. Everyone can tell if it's oiled, or if it's got protective finishes on, and so can everyone else. It looks a bit yellowish, uniform, plastic and non-natural - and it's actually not as grippy as natutral teak. There's also fake teak, which some boat builders can tell you is actually twice the price of real teak. But we humans are very good at identifying real and synthetic materials even from a good distance away. Teak should look like raw teak – just a like new boat at the boat show. Any teak can look like that again.
2. Firstly, the chemicals. You need two-part cleaner which can be obtained from Wessex Chemicals. I haven’t found anyone else who does the right stuff, although others have better names than er “2-part teak cleaner” which is what they call it.
You get this in 1-litre or 5-litre or 10litre plastic containers, a few quid a litre. Expect to use around 3/4 litre of each for a biggish 60foot boat at each clean. If you buy in bulk, mark the containers "part 1" and "Part2” clearly as the coloured dye can go off after year and you can't easily tell which is which. Incidentally, the part two in concentrated form removes rust stains, which is handy, but make sure you rinse it afterwards.
3. Now , the kit: NO BRUSHES, NO JETWASHERS. You need the mildest possible way of swooshing around the boat, and on new teak this means a sponge. But a sponge on a stick, so a Vileda floor mop thing that squeezes out is excellent. For outside teak tho, esp teak which is a bit “ridgy”, the floor mop will get destroyed and stick on the ridges. The Surehold range or similar is good - you get a long stick and put attachments on it , red handle – thats the one, and get the flat attachment to which you can stick on a pad that looks like a pan scrub. You want the very mildest one, a white one that is soft enough to wash your face with - only just not a sponge, not as severe as a loofah. Plonk this on the flat face of the attachment.
Okay, look you MIGHT need a brush if you teak is very heavily knackered and this is the first clean for years and years. A brush will get into the ridges - but digs out the softer material at the same time. So use a soft brush if you really must. But non-ancient boat or teak under five years old - no brush.
Oh, and you need a hose too, hopefully with a decent end attachment. Actually just a bare end is ok so the water “drops” out: it’s important NOT to have it on a “blast” setting like the cheapest hose ends – better ones have 6 options, and for teak you should only use the setting for what feels like “rain”.
3. Cleaning even a colossal floor takes minutes, not hours. Get everything out of the area, tables chairs etc so no water goes on anything except the teak. Screw-down tables need to be out as well. Hoover dusty inside areas if necessary.
Then wet the area with water from hose NOT blasting, just dribble about with the hose set to “gentle rain”.
To be continued..
Now, the key thing is that you need this to take a short amount of time - so hands and knees is hopeless as you will never do it more than once - an effective AND quick clean is what we want. I saw one guy cleaning the deck with toothbrush! – not for us I’m afraid.
4. Mix a mild dilution of Part 1 in a bucket and wipe it on to the teak with that floorpad mop thing. “5 water to 1 chemical” is the most severe you shoud use ever on mossy greenish teak, but try 10water to 1chemical to start if it's just greyish.
The teak will go very dark almost immediately, the colour of mahogany or even very strong coffee. Urgh! – a bit worrying! And the spashes on the bits you haven’t done – they’re just as bad! Don’t worry.
Keep putting the solution on, and agitate the stuff over the teak, across the grain. Use that floor mop to sloosh it around, always across the grain gently, with the soft spongy pad.
As it goes dark, there's a tendency to not bother rubbing everywhere cos it’s “doing something” but you do need to "apply" it to the wood with the sponge/mop thing, not just rinse over. At the edges, use a mild handheld green plastic panscrub – again, not one too rough to wipe your face with – to get the edges – otherwise we won’t have the “new” look as the middle will be clean, the edges murky.
Saftey warning: SLIPPERY with Part1 : the teak loses a LOT of it’s anti-slip properties with this part 1 on so be careful and keep kids and the unwary away. On an open a sailing boat deck, be especially careful as you move around – and with the next stage too. But when finished it’s back to normal, of course.
5. Pretty much as soon as the diluted part 1 has been put on everywhere and gone worryingly dark brown, it's done the business. So once it is all uniformly wet and dark, rinse the area, and tons of brown gunk will come off, often quite a shocking amount. But imagine how filthy your car would be if you left it unwashed, just rinsed a bit now and again, for a year or more. You need it all this off. I use a rubber window wiping blade on a stick to swoosh it all out. Again, don't blast with water - use low pressure and lots of it.
6. Now the part two, the red stuff. Again, mild solution. 10 water to one P2 on wet teak after part 1. This is worrying to put on because it bleaches back the colour, and even the bucket seems to leave a mark. Argh! Again, don't worry - it will all come back bright as the bleachiness goes all over. Not much skill needed - provided you stay at a mild dilution, you can't put "too much" on - it returns to it's natural colour, so it won't go white or anything like that.
Another warning: this is a mild acid, so it will sting cuts in unprotected hands and feet. But your hands and feet don’t drop off, or at least mine haven’t been damaged anyway and I’ve done this a fair bit.
On big patios or on the pontoon (yep, you have to clean the pontoon too soon, see below) I use a garden watering can and a rose to sploosh it on. The part 1 get’s the gunk off – this seems to hardly lift any more dirt, just turn back the colour. You do need to rinse off the part 2 though.
If you missed an area with p1, it'll be silvery grey after p2, so yerd have to start again –or praps leave it till next time.
You need to carefully rinse metal items around on the floor – stainless or aluminium won’t get horribly damaged provided you get the stuff off during the rinsing so target these especially.
I wipe with a “blade” (like a windscreen wiper) to speed up the drying process, and get the dirt off without needing tons and tons of water.
Walking on the now-clean teak whilst it's drying means you lose the "utterly fab clean new-boat" look, but clean footmarks do evaporate so it's ok, ish.
Now, the teak looks brand new when it dries. Hurrah! Is it clean tho? Get a white tissue and wet it, wipe on a bit of the teak, and the tissue will remain white clean. It's clean enough to eat food from.
7. Soon the teak will get filthy and go silvery grey again. Why's that? Well it's cos of the rain, or the air or (mostly) cos you or the crew did it with your feet. In the med, big boats are "no shoes" - you step aboard in bare feet, not deck shoes, not socks, but Bare Feet, even if you charter the boat and pay a zillion pounds a week. All those swanky boats, look at the pics closely and none are wearing shoes. Ok, on some they ARE wearing shoes, but they are either deck pumps (that always stay on the clean deck) or nitwits.
8. To keep the deck clean, I'm afraid that you need to try a bit harder than you are doing. You have a deck that is utterly clean and visibly so, like white carpet. But the pontoon is filthy. It's like having muddy garden path and muddy driveway, and white carpet indoors. You need to instigate a regime to limit the dirt arriving on board.
Clean the pontoon where you step aboard for a start, using 2-part teak cleaner again, and this time use a brush because it will be filthy, it’s already ridged, and erm, it’s not your expensive boat.
To be continued.....
If the quayside of you normal berth is concrete, clean and then paint it with garage floor paint. Put a mat down on the quayside for changing shoes. The mat will fly away in high wind so make sure you have spare mats and take it up before a gale. I lose about one mat per year, mebbe two. If you can't be shoes-off on board the boat cos in the uk it's cold, have one pair of shoes for schlepping over to the car park etc. and dedicated shoes on board that are only for on board, never ashore.
9. Knackered ridgy teak. Teak feels as hard as nails – dense and unyielding- but is actually quite susceptible to being washed away, perhaps like very weak concrete.
To keep it from disintegrating, you need to never clean it and never wash it, and never step on it and keep it covered ! - but this aint possible on a boat. A winter cover (over the whole boat or at least over the teak) makes it last longer. If you have bare teak indoors perhaps in a wheelhouse, and also outdoors on the deck, you'll see how the indoor stuff stays new and flat and not-ridgy for much longer. The rain does this – it’s a moderate jetwash that happens lots of times per year. So, if you had a cover, or individual covers for bits of the deck, your teak won't go ridgy anywhere near as quickly. The cover needs to allow air to circulate to stop it going mouldy a bit, but never with rain landing on it. Le Grand Bleue is Abramovich’s ugly ship with loads of playtime boats incl a big 70 foot powerboat - and the first such boat (Sirius) had individual canvas /Sunbrella covers for the teak held down with poppers when owners aren’t on board - and the teak is lovely, even after a several years.
10. Sanding the teak. Yeah, well, you need a machine to do this, and make it flat. Easy to describe, hard to do and makes a right mess. Once the teak is flat, you can make it smooth with finer and finer sanding, tho it will be slippery if you go on too long. It will need sanding eventually. Be very very careful with a beltsander cos it will eat a lot of material very quickly: much safer is an orbital sander with about the grittiest grit you can find: yeah, 40 grit might feel awful to your hands but it still takes a while to get the teak flat. First off, the sander dances around as it “grabs” on the raised black caulking. Then, it starts at the hard raised ridges but it still takes time even with 40grit. Get a decent machine with lots of watts – the £12 850w units aren’t good enough and get groaningly slowed down.
Its ok to leave it a bit de-ridged rather than grind down to "new" – clean as above and you still have new looking deck with far less ridges than before. Professionals seem to insist on whamming it down to “new wood all over” which must use more material and limit the number of times you can sand.
11 Finally, about the semco and other protective coverings again: at the cost of it looking like real natural teak, these stop dirt from entering the grain. So, it's sort-of protecting the teak for the next owner of the boat. I suppose you could use these over winter, that would be okay. But would a top-class superyacht or classic racer use these protective finishes, or teak? No they blimmin well wouldn't, they'd be chucked out of St Tropez and the skipper doomed to everlasting ridicule! Teak means teak.
I have seen the Wessex cleaner and brightener chemicals advertised.
But I wondered if inexpensive alternatives are available.
I may continue with the idea of experimenting on the garden shed (and furniture) as I have a large shed that could do with a facelift.
Perhaps the expensive cleaner would be best for the expensive teak on the boat.
I suspect that your shed would cost a whole lot less to replace than your deck.......
Wessex is great stuff. You only need to use it a couple of times a year. This deck was 11 years old and had not been cleaned (other than by sea or rain water) for at least 5 years......
Can I refer you to my post #5 and the attached PDF and caution.
No axe to grind. Maybe they're just trying to sell their product - but it's worth thinking about/researching (i.e. acid cleaning treatments and the effect on caulking integrity).
