vic008
Goiot windows have the remains of stickers still sticking, proving hard to remove. Suggestions please
If these are acrylic, or any other polymer - I would not use a metallic scraper.
Find an old piece of acrylic and grind the edge to about a 45 degree angle. Grind the edge using a fine grading wheel. so that it is sharp. It should finish looking like an old fashioned plane blade. Use it as a scraper. If you have lots of windows the acrylic will need sharpening occasionally and making the 'non working' end into a handle will make it easier for your wife to do it. The 'blade' needs to be straight and if you are careful in how you make it - it will go into corners. A sophisticated tool like this is excellent to remove silicone etc. and will last your wife a lifetime.
You may need to soften the adhesive with solvent, diesel might work as also might turps, acetone or meths - your guess will be better than mine.
Jonathan
Paul, Acetone and acrylic - good warning - if they are decent windows and reinforced glass - then it might suit.
But I did forget
Jonathan
