SailBobSquarePants
My Mariner 3.3 2 stroke outboard developed a bit of rust around the piston rings, and consequently decided to seize last weekend. It had been stored in a shed after flushing with fresh water, but I did take it off the boat quite late in the season - lesson learned.
I removed the sparkplug, dosed it a few times with WD40, and managed to get the piston free. Using the flywheel bolt, I can move the piston completely up and down in the cylinder - however the flywheel itself will not rotate a full revolution - just back and forth over perhaps 70 degrees of arc, during which time the piston rises, and then falls when the flywheel is reversed. I am guessing that is normal, and there is nothing more I need to do to unsieze the engine?
Secondly, when I look into the cylinder I can see carbon deposits on the piston, and there is just some general muck and junk in there. The sparkplug itself was fouled with something reddish. What I would like to do is clean out the cylinder before I replace the (new) sparkplug - someone recommended Seafoam, but that seems to only be available in the US. For us UK dwellers, does anyone have any suggestions? Diesel as a cleaner, perhaps?
Many thanks!
Many thanks!
