Classic Anchor Light Lens replacement
Roach1948
27 Apr 2006
www.dallimoredesigns.nl
After spending a fortune on electrical fittings to convert my anchor light from bulb to LED I was a real idiot and managed to drop the glass lens when putting it all back together last weekend. Anybody any ideas where I can get a new (old)melon shaped glass lens? Dia 1 1/4" with 1 1/2" lip/flange
PS. Already tried Classic Marine!
Re: Local grocer?
Do you know, I think you are onto summat there!? In fact any smallish screw topped jar could be made into quite a decent all round white / Anchor light. Probably best if it had a rubber sealing ring in the cap?
Fix bulb holder to underside of cap, pass wires through rubber grommet in cap,screw cap to mounting bracket or whatever with a bit of sealer under it. Fit bulb, screw jar to cap with a bit of non setting sealer on the threads and there ya go!
Probably do the job for a fiver! /forums/images/graemlins/smile.gif
Mind you, you can always go to your local swindlery and pay about 8 times that?
