macd
Echomax RTE, X-band only, £360 new on ebay
Same prices from Cactus: http://www.cactusnav.com/echomax-active-radar-reflector-p-10988.html
I think Roger knows that I was just doing a little bit of digging. If I had to choose between the security of an active reflector and an AIS receiver, I would certainly have a problem but between a reflector and class B, it would be reflector every time.I don't see it that way. Isn't it more a case of spending effectively? A Class B transponder is £450 - the same as a Sea-Me or Echomax Active radar reflector. The difference is that the active radar reflector always works to enhance your visibility on ship radars, whereas the transponder might, or might not, depending on whether the ship is filtering out Class B clutter. It's a no-brainer.
From earlier threads on this subject I learned that the Vesper Marine WatchMate, while not filtering Class B targets per se, can filter alarms based on various parameters, one of which is SOG. This means one could set the minimum speed as, say, 8 knots, under which few commercial ships that pose a threat rarely operate and that constitute the bulk of recreational sailing vessels that consistently activate my alarms when they tack into my CPA boundary set for the dangerous commercial ships, especially fast ferries. Sadly, OpenCPN running on a netbook that I have below on the chart table being fed by my AIS input, has very limited alarm filtering and without that function.Sadly, leisure boaters don't have the luxury of filtering out Class B targets! Unless, of course, we buy rather expensive ship radars...
Again, I must agree with you. I have seen enough AIS Class A static data from clearly underway ships showing them as 'Moored', for example, to not trust operator entry data.I don't think the Furuno menu you've quoted is much more complex than a lot of the button pushing we do on our plotters. However, you raise a good point in suggesting they might not bother to turn Class B targets back on. Another reason for not trusting Class B transponders to guarantee that you're seen!
It was obvious from the beginning that widespread take-up of Class B transponders had to lead to ships simply filtering them off their radar screens.
Easily countered by an expert witness for the defence in the form of Dr Andy Norris, who has publicly defended such action with:One visualises the following exchange in a court of law:
QC: 'My client had an AIS transmitter. Why did you not see him?'
Mariner on trial: 'We filtered people like him out ...'
QC: incredulous silence followed by: 'You mean you switched off a vital piece of safety equipment?'
The Furuno FAR-2107 Operator Manual implies otherwise (see post #44) As does the Furuno representative's comments in the Panbo article (http://www.panbo.com/archives/2010/12/class_b_ais_filtering_the_word_from_dr_norris.html#more) and quoted in that same post. That is my interpretation, I am willing (nay, eager) to be proved wrong.It is true that Class A vessels can place a form of filter on a target, but the watch keeper cannot remove the target from the screen.
Great that you have the facilities to check this out, Jack. It is indeed a grey area and I look forward to your professional opinion on what is truly implemented on the majority of ECDIS and ARPA equipment. Thanks for that.in reality I think you have little to worry about - whether decluttered or sleeping or activated - you will alarm when you hit the target vessels CPA/TCPA minimum parameter - you cannot be 'turned off'
Ha ha - its really not that bad out there. We seem to be concentrating on one particular tool, in a plethora of skills and equipment at the disposal of the watch keeper. The academic question is how to resolve the grey areas that exist in the legislation that surrounds any new piece of equipment, and then how that is interpreted by the various manufacturers to ensure mistakes through lack of training are not made (ECDIS is a classic example of this). The regs on AIS dont provide complete clarity, the standards do call for the ability to declutter a sleeping target, but SOLAS V - Annex 17 does call for any target (sleeping or not) to activate an alarm on entering the minimum CPA/TCPA parameter - (Class A or B). The lack of clarity in discussion here is whether the target having been 'removed' might be removed from this function. i am reassured however that with this need being in SOLAS V it would be a desperately incompetent manufacturer that would allow this to occur. It does however lack complete clarity when reading the manual. The fact remains the interpretation of the manual when not read in parallel with the standards nor the SOLAS requirements could be interpreted 'for the worst'. My next task is to get onto a Class A boat with this function and test this out.....or I suppose i could just phone Furuno.....but in reality I think you have little to worry about - whether decluttered or sleeping or activated - you will alarm when you hit the target vessels CPA/TCPA minimum parameter - you cannot be 'turned off'
Wow - I hadnt spotted that - its amazing if this is possible. I have run this past a few master mariners here who could not even conceive this was possible nor desirable. A target of whatever size/class is a target - Class A, B, and no 'class at all'.....hence the assumption that the SOLAS wording would encompass you as an existing target - displayed, filtered, sleeping, or otherwise. by the time you are in traffic of such density that requires you to do this, or indeed reduce your CPA/TCPA alarm parameters to exclude such 'targets' you are well beyond the functionality of AIS as a collision avoidance tool and down to constant close monitoring of radar and mark 1 eyeball, probably with a helmsman and extra look outs on hand. So why on earth have such functionality?
Do a search on panbo and gcaptain - it does seem that one foruna model if you jump through enough menu hoops you can switch off class b targets on the display but they will get turned on again if in the acquisition zone unless you dig intop the menu deeper and turn off cpa alarms as well, or something like that. Some interesting comments on gcaptain from the big boys, no one knew that deep in the menus how to do it and wouldn't bother anyway. And everything will still show up on the the ais transponder.I am glad I got involved in this discussion as it has clarified some things for me, especially whether there are AIS displays which can have Class B vessels filtered from their screens. As pvb has shown some do exist.
It is interesting though that my previous searches had not found them; but I had been looking at current products. Looking at current Furuno products this feature appears to have been excluded now - unless I am missing it. I have looked at the FMD3200/3300 and FA-170 units.
Could it be that manufacturers now think this might not be such a good feature? Of course there will still be some older units out there.
As stated by others IMO do not present AIS as a Collision Avoidance tool but do say it might be one day.
