vyv_cox
so I cannot get stressed about TBN
Inappropriate TBN is the main reason why I believe that using higher grades in old engines is bad for them. Originally it was a large boatyard in the north of UK who told me of their experience that bore wear was heavy in yachts using high grade lubricants. They advised all their customers to use an API CD, at that time Shell Rotella C (spec now changed).
Thanks to my contacts in research I was able to take this info further. My good friend and ex colleague has carried out hundreds of wear tests on lubricants with different chemistries. He confirms that high TBN in conjunction with low surface temperature in the sliding contact promotes higher wear rates.
As others have said, there is loads of experience in historical agricultural and automotive operation confirming that new oil and old engines don't mix.
