ulyden
Just remember there are some differences in car chipping and boat chipping.
If you chip a car with maximum speed of 200km/h 20% up you get 6% extra speed.
You need 250rpm more if your maximum speed is at 4000revs like most of all diesels are these days! In this data sheet it’s all ok!
http://www.hs-elektronik.com/datenblatt-d/bmw-e87-118d-122ps.html
Problem is that a lot of diesel cars are propelled to light! Old BMW 320 for example is running 4400 at top speed! You see then that engine power is down to 110hp in this case! If you don’t change the ration on final drive you don’t get more speed. Your acceleration is much better. But how long are you using maximum acceleration? You need 10 seconds to 100.After 30 sek you are at 180! That is the time you are running with higher power. As long as your gear ration is the same the power is the same at a certain speed! A car engine (BMW) is designed for 200 000km at full power. At top speed of 200km/h this is 1000h. That is on of the reason why the boat pleasure ratings are higher. The engine is designed for only 300h at full load!
Load profile. A modern car with a D3 or a similar engine can reach 200-220km pr hour! (120-130miles/h) How many are using this speed? Most countries in Europe you can drive 130-150km/h on highways! This means a cruising speed of 70% of maximum (2800rpm on a 4000rev engine) or 36% engine power!
In Norway maximum speed limit is 100km/h and my BMW is using 10% of the engine power at cruising speed! That’s why I have chip tuned my car! Even if the big torque is to strong for the clutch and the damping springs in the clutch!
If you chip a small van that’s maximum speed are 120 and increase the maximum speed to 130 and are using it all the time the situation is more like a boat!
A fast boat runs 10% speed reduction or 76% engine power. Older engines (No common rail) could run continues 95% speed or 88% engine rating! If you chip tune one of these you can risk cruising at 108% rated load! Don’t think this is clever!
Also remember that to map an engine you needs a lot of things. You need a brake with monitoring and control system. You need an emissions rack witch is quite expensive!
You need to measure the firing pressure in at least one cylinder! This is expensive! You should also monitor the needle lift in the injector to se the injection period!
You need a fast monitoring system so you can calculate the IMEP ROR also se the filling rate and the opening pressure the exh.valve mechanism has to work against!
Then you need of course the normal data as temperatures pressures in cooling water, oil ,charge air, exhaust outlet end inlet of turbo, back pressure ,boost pressure ,rail pressure oil pressure ,cooling water pressure and so on.
Then you come to the tricky point. You need to know the limits for firing pressure, injection pressure, needle lift period, exh temps. Valve opening force, maximum turbocharger speed, maximum exh. inlet temp on turbo, maximum exh. valve temperature, maximum boost pressure, smoke limits nox limits and so on. If you need to measure the particles it needs a hell of instruments and the cost is very high!
When you are finished you need a new test certificate on the emissions levels are within the IMO EPA or other limits. This is a lot of documentation work! You have to make a new technical file and if you are selling it to EPA you have to make documentation that it will be within limits for at least 1000running hours or useful life time!
You should also know if there could be any torsion vibrations in the crank shaft to consider!
I have asked chip tuners for documentation of the new maps. I have never seen any!
I know it’s easy to remap an engine! I do it very often. If I could get 1000p for the job and no warranty claims I could make a great business! Even cheaper doing it without any test cell.
Just add on more fuel boost and advanced timing! Then I really could make money!
