jimduncan1
Hi,
Just wondering whether anyone has any experience of using chip-tuning to boost performance of their Marine Diesel engines. I saw this chip for a D3 160HP which boasts an increase to that of a 190HP. I understand that the D3 160 engine is virtually the same as the 190 except for the ECU mapping but am open to correction.
The product description below comes from Chip Express (http://www.chipexpress.com/diesel-tuning-box-volvo-penta-d3-160-marine-kit-1683.html) however there appear to be several UK providers.
Appreciate any views or comments. Thanks Dave.
From Chip Express:
Power, Economy and Drivability...
Looking to improve the power, economy or drivability of your Volvo Penta D3? The CHIP Express™ tuning system is without doubt the most advanced plug-in diesel upgrade available! It works in harmony with your engine, retaining all safety functions without needing to interfere with the vehicles existing on-board computer. While most tuning companies aim to provide maximum power, our aim is to improve the overall drivability of the vehicle, making it feel smoother with a much more progressive power delivery. Our system will free your 160 Marine from its manufactures limits, letting you decide how to drive! Now with a 14 day money back guarantee and a 3 year product warranty!
Self-installation poses no problems...
With the aid of photo illustrated instructions supplied, installation can be carried out quickly and easily by anyone with competent DIY skills in about 5 to 10 minutes using simple plug-in connectors. All systems fit in the engine bay downstream from the ECU and can simply be removed without trace in a matter of minutes. Remember our quality products are backed up by an outstanding after sales service; should you require any telephone assistance during your installation we will be more than happy to help.
Intelligent, Adaptive, Multi-Map Technology...
Our microprocessor controlled tuning systems will adapt to your vehicle and refer to any pre-programmed fuel map at a rate of up to 40,000,000 instructions per second (40MHz). This allows intricate adjustments to the cars fuelling by precisely calculating the injection amount depending how the vehicle is being driven. This intelligent feature gives the unit the ability to work in harmony with your engine, providing economy or power depending on your driving requirements, a feature never before seen on plug in applications!
Kind to engines and diesel particle filters...
A further advantage of these new add-on electronic control units is their compliance with vehicle emissions standards. This new clean diesel technology works by improving combustion efficiency making soot and smoke things of the past. Because of this, installation of the tuning box system is also possible in vehicles with diesel particle filters and urea injection.
TÜV approved with C.E and ISO 9001 status...
The quality and performance of our systems is paramount. Our digital micro-processor circuited units are all manufactured using the highest quality surface mounted components contained within a compact, light weight, water resistant and robust aluminium housing. In addition only original adaptor plugs that simply plug in to existing connectors are used. Rest assured you are buying the best quality, most rigorously tested system available that has achieved TÜV and C.E approval; very few companies can boast such credentials!
More power by Adjustment...
All boxes come pre-set for optimal power and economy so adjustment is not necessary, you can simply plug-in and enjoy! However, if you require more performance the power level settings can simply be increased in small increments using the included instructions. This is particularly important to people who want the maximum power from their diesel or those who are planning to make further modifications to their vehicle.
CHIP Express™ Volvo Penta D3 160 Marine performance results:
Volvo Penta D3 Standard Power
PS-BHP Tuned Power
(After / Max) Standard Torque
Nm Tuned Torque
(After / Max)
160 Marine 163 196 / 224 340 424 / 462
"After" figures show the power your vehicle will produce on the supplied settings. "Max" figures show the power your vehicle can produce if adjusted to a higher setting. Not all vehicles will achieve "Max" figures when on a higher setting, most standard vehicles will achieve a power between "After" and "Max" figures.
Why choose a CHIP Express™ system?
• Provides a driving performance second to none
• Unlocks your vehicle's full potential using TUV certified, tested software
• C.E. approved with ISO 9001 quality assured chipset technology
• Simple plug-in fitment (no cutting of wires), easily adjusted, leaves no trace once removed
• Unlike a remap our systems cannot be detected or deleted during routine servicing
• Does not require the removal of your vehicle's original programme settings
• Produces more low down torque compared to a remap, ideal for towing
• Superior performance on demand whilst keeping the engine standard at idle
• Select higher gears sooner, down change less, reducing RPM's, improving economy
• Use less throttle for similar driving conditions, further reducing consumption
• Eliminates flat spot, reduces turbo lag and sharpens throttle for a smoother drive
• Makes more of the RPM range usable, for safer overtaking
• 14 day trial and 3 year product warranty
• Compliant with vehicle emission standards, suitable for diesel particulate vehicles
• Kind to engines and transmissions (automatic compatible)
• Digital and reprogrammable for use on your next vehicle *
* On most vehicles you can keep your existing tuning box. Usually all that is required is new software and possibly a new adaptor cable. We charge a fixed price for re-programming and an additional fee if a new adaptor cable is necessary. Even if your system is not compatible we will offer you a fantastic part exchange on your old system as long as it is less than 2 years old. Please contact us for further details to check the compatibility of your current system.
How the diesel tuning system works...
Today's diesel engines have many sensors which are connected to the vehicle's ECU (computer). Using digital microprocessor technology the Chip Express™ system intercepts, analyses, and alters the signals between the ECU and injection system, calibrating for the most efficient amount of fuel depending on the driving requirements. This is facilitated by utilising the extra air available (as much as 50%), provided by the turbocharger whilst still remaining within its safe efficiency range. Because of this the fuel consumption is improved as you now require less throttle and RPM for similar driving conditions.
From Chip Express:
PS-BHP Tuned Power
Nm Tuned Torque
(After / Max)
