alanwilson
Just installed a Chinese diesel heater (5kW): worked perfectly first time. Didn't use the silencer (pressed, not welded), but didn't need it: very quiet running. The main problem is deciphering the "manual": eventually got most of it sussed, but can't find an explanation of how to control the output.
It is easy to set the target temperature; but you can also set the pump pulse rate in Hz and the fan speed: why?
Setting the target temperature automatically produces high output until that is reached, then lowers the output: presumably by reducing either the pump pulse rate and/or the fan speed, so why would you want to separately set either the pump rate or the fan speed?
What am I missing?
What am I missing?
