Chimp RH bilge pump
PabloPicasso
12 Feb 2010
I have a bilge pump with CHIMP RH in letters on the base of the pump handle. It still works but dribles a bit into the cockpit when pumping so I'd like to give it a service.
Anyone know if spares are easily available, and if so where from? A quick google search wasn't very helpful.
Chimp spares here, don,t know if yours is though.
Apparently the RH in Chimp RH stands for removable handle. there are no identifying marks on the pump so I will have to disassemble before being able to order spares.
I'll let you know how Iget on
Have you tried "Force 4 "online? i have the same pump and i get my spares from them.
on the second Diaphram in two years now.
I have the same pump and just got back from local chandlers where he told me the service kit was approx £50 :eek:
What I'm contemplating is getting a new upto date pump instead BUT as it is thru deck mounted there is quite a large hole , does anyone know of a replacement pump that will fit the hole ? , it worked fine , I'm just not feeling the £50 for a peice of rubber !!!!
Whale & Henderson are same company by the way ..
I have 2 through deck Whale bilge pumps, but they don't look like that; they have a straight tube handle which fits into a tubular socket on the bellows, so worth looking at the Whale range - sorry I don't remember the model.
Looks like the Compac 5 is the modern version of mine.
