Keen_Ed
Have to admit that I use the compare agains the background method for the last 10 years while racing in the Solent. In discussions with an American, she called it "making trees". If the boat is moving forward compared to the bank - i.e., the scenery is being revealed from behind the other boat's jib, you're "making trees" - and will/(should!) pass in front.
A few notes. It works best when you're both beating. The time you really want to be in front is when you're trying to cross a starboard tack boat when you're on port. So what's critical is the last 30 seconds leading up to the cross.
And if you have any sense, you want to leave a bit of a gap if you're crossing on port (At least half a boat length in ideal conditions - more in windier)
If you're sailing at 5 knots, your VMG is going to be something like 3.5 knots to windward. 3.5 knots is 6 feet per second. So in thirty seconds, you travel 180 feet directly to windward (and 180 feet sideways). If the shore is 4 miles away (easily done in the Solent), then the bearing change with a fixed point ashore is half a degree.
