[3889]
The vapour pressure of CO2 at 20C is ~750 psi. I don't think many airlines will match that. I would suspect the cylinder was oversize, either through fitting the wrong one or residual gas in the bladder.
Yes, misinterpreting.I'm sorry but I don't understand what you're saying here. Are you suggesting that jacket pressure reaches 750 psi? That’s 51 atm!
Take a look at http://www.ybw.com/forums/showthread.php?312911-66g-lifejacket-cylinder-what-volume
Or am I misinterpreting?
The CO2 might be at high pressure in its cylinder, but when it escapes into the jacket its volume will increase so the pressure will decrease.
My apologies.Yes, I'm with you on that, cylinder not relevant.I thought the inflation was by compressor, adjusted in some unspecified way so as to give normal inflated pressure in the jacket ? So I don’t see where the VP of CO2 or a larger cylinder comes into it.
Single chamber leisure jackets DONT have prv's. Jackets will take their "form" or shape at around 100Mbar. Jackets are tested by approved service stations at the level specified by the manufacturer. Usually around 150 to 200 Mbar.
ISO specifications dictate that a jacket should be able to withstand 1Bar of pressure. You could easily fire two 33g/38g cylinders into an ISO jacket without it bursting.
From my school days 1Bar was 1 atmosphere which was 14 PSI- is that correct?
Therefore 2Mbar is 2.8PSI. Is that right?
I can't remember for sure, but don't LJ's have inflation pressure printed on them?
The lifejackets are of unknown age: Came with the boat. I've had them 6 years. They're minimum 10 years old, more like 15, maybe more.
The jacket belonging to the OP was stated to be about 5 or 6 years old. This pre dates ISO 12402 an would have been covered by EN 396. (very similar)
If the OP's jackets were cheap Chinese imports then non of the above applies and the rest should be thrown on the bonfire.
Your point that the jacket must have been well over inflated or well rotten is pretty accurate I would say. That's the reason that people who are unsure should have their jackets serviced properly. The cost is only about £10.00 +/- pr jacket.
These only have "Use with 33gms CO2 Cylinder". They did/do have 33g cylinders. I've emailed mullion to try and ascertain age/pressure from a serial number (no model number printed on any label).
Are you sure it is CO2. Imagine someone topping up the inflation tubes by mouth & accidentally getting a mouthful of CO2. Or come to that actually deflating the jackets in a confined space after useAh, 33g of liquid CO2 will give 33g of gas. So it should be possible to work out its volume at room/sea temperature and any pressure. Then you just need to know the volume of the jacket bladder...
Mike.
Would not help much would it. I know that there are non return valves but in the event of problems CO2 cannot be the most user friendly.
I can hardly imagine cylinders of compressed oxygen being a top plan for life jacket inflation, and as every other gas is effectively as poisonous as CO2 just by dint of not being oxygen, I think you will be stuck with it. It's not CO
Quite hard to orally inflate a lifejacket without putting a lot of CO2 in it either.
If people breathed out pure CO2 there wouldn't be much point in mouth-to-mouth
