Simon391088
Hi,
Visited Lymington at the weekend. Doing a turn on the spot (twin engine outdrives) - with lots of expensive boats parked all around.
Put Rudder hard to starboard, port engine in forward, starboard astern. Suddenly loud continuous beep, no power from starboard engine.
Message says 'Check Shift Actuator' on Starboard engine dial.
(D4 260hp).
I managed to back out using Port engine and briefly tie to the ferry quay.
Quickly got starboard engine going again. - not totally sure how - under pressure from harbour master to get out of the way of the ferry!
No further problems for entire weekend.
Questions....
1. What happened?
2. I'm not even sure that the starboard engine stopped, I think it might have still been running but failing to get into gear. I have a feeling that I should have acknowledged the beep by pressing the evc button and then tried to engage Gear again, but I assumed the engine had stopped - you don't have much time in such situations!
3. The boat (2nd hand) is still under warranty) what needs to be done?
Any thoughts welcome.
Many Thanks
Simon
(D4 260hp).
Questions....
1. What happened?
Many Thanks
Simon
