LukeS
Hi all, following a heat exchanger failure on a VP D2-40 I am concerned that I may have had some coolant get into the cylinders. I found water in the exhaust manifold when I took the heat exchanger off - and in at least 2 of the exhaust ports on the engine block. I’m worried that if I try and start it up with water in a cylinder it could cause no end of damage with the high pressure. Or can I simply operate the injector stop lever so that it won’t fire up and see if it will crank over under starter motor. I don’t know whether that is powerful enough to do damage or whether it would “just” hydraulically lock if there was water in a cylinder.
Any suggestions on how to check and clear out if necessary? I was thinking of removing the injectors and seeing if I could look inside each cylinder using an endoscope camera. Not sure if that would work or if there are better ways?
Luke
Luke
