Cheap, non-volatile, thermally conductive fluid?
Ric
8 Dec 2003
Hello,
My Volvo MD2020 only has a crude on-off overheat alarm, and I'm too disillusioned with Volvo customer service to pay them any money for an analogue gauge.
Out of curiousity I would like to experiment with a digital thermocouple in a couple of external cavities in the casing of my engine (unused bolt-threads etc) to see if I can use this as a warning of overheat problems. I have found one particularly promising hole in the cylinder head into which I can insert the thermocouple. Can anybody suggest a non-volatile, odourless, cheap, thermally conductive liquid which I could use to ensure optimum thermal contact?
VicS
13 Jul 2002
Oil would do the job!
but I suspect just inserted dry and the top of the hole plugged would be good enough.
The liquid with the highest thermal conductivity that I know of is mercury but I'd not recommend that you use it !
Water would evaporate!
team OSD
27 Sep 2011
The Netherlands, Tiel
How about heat conductive paste? It´s a conductive mixture of magnesium/zinc oxide and silicon oil. Widely available are different kinds of paste, some melt at 120C, 150C an the expensive one´s at 165C or more.
a Little package 3 cc; between 2 and 6 euro.
ed; Semisimple beated me by minutes!
William_H
28 Jul 2003
West Australia
Thermocouple
As said the conduction of air in a tight bolt hole should be adequate however the paste used by electronics people to improve conduction of power transistor body to heatsink is what you need. (usually white)
I don't know whether you are aware that piston (air cooled) engine aircraft often have a cylinder head temp gauge in the form of a washer that goes under the spark plug in place of normal copper washer which is a thermocouple. (2 metals) It is quite sensitive to change indeed enough to be used to adjust mixture from CHT. However your diesel engine may not use similar copper washers. The idea however is very applicable to checking cooling as the hot head is exactly what you want to avoid.
This aircrraft type CHT could be ideal for outboard motors. You could buy just the thermocouple or a complete kit with meter from aircraft spares suppliers. olewill
farmer.leo
8 Oct 2011
Antifreeze.
You don't want if freezing, it conducts temperature away. Oil is also an idea that sounds good. Maybe the manufacturer of a thermocouple could offer a suggestion.
