VicS
With the fate of the Ouzo still in the back of my mind I decided to time had come to replace the 30 year old nav lights.
Very pleased to discover some lights that would replace the old Aqua Signal 25 lights without having to drill new holes etc and at a significantly lower price.
See the old and the new below. New ones made by AAA Worldwide Enterprises of Taiwan.
The trouble stated when I wired the new lights. Tightened the grub-screws. Gave the wire a gentle tug and it came away in my hand. Rewired with same result.
Investigation showed that the terminals in the new light allowed the grub screw to go right through neatly chopping off the wire instead of clamping it. Diagrams below.
Now what is the solution.
1./ Tin the end of the wire so that the grub screw does not slice straight through.
2./ Cut some bits of solid copper from some old T&E, solder the wires to those and insert the solid wire into the terminal.
See the photo below.
3./ Clean up the old Aqua Signals, the terminals etc are pretty corroded after 30 years, and fit the lenses from the new lights into them. yes they do fit .... exactly!
Be warned if you have bought any of these lights from AAA !
<span style="color:white"> ........ </span>
