Bru
Most plotters will work down to about 10v. If the OP's plotter is turning off, there's either a big wiring problem or the batteries aren't adequate.
Hmm. Often more like 10.5v to 10.7 (most Raymarine equipment, for example) will power down if the voltage drops below 10.7 volt +/- 0.1 to 0.2v
I'm still hoping the OP will advise whether this has always been a problem or whether it is a recently developed phenomenon. If the former, the cause is probably inadequate cabling sizes, if the latter the cause is probably tired service batteries
Either way, I would prefer the solution of fitting a separate bow thruster battery and a three way charging system to kludges such as tacking on an extra battery to boost the voltage to the instruments or using the engine start battery to power the bow thruster (I have a particular fetish about keeping the engine start battery strictly for engine starting and, via a removable key cross-link switch, emergency backup for safety critical systems).
