Chartering
Poignard
23 Jul 2005
South London
Looking at prices in Galicia I can rent a modern yacht for 200 euros a day so between two couples it would be quite reasonable to sail around the ria for a day to see if we are still fit enough and compos mentas,I have certificate for patron which should be adequate,it’s an idea🙂
"... to see if we are still fit enough and compos mentis..."
That counts as negative thinking in my book.
"Do not go gentle into that good night etc"!
Wansworth
8 May 2003
SPAIN,Galicia
Careful! You might get a taste for this sailing lark. 😁
(A great idea, except it's distraction from actually making a decision! :devilish: Note also that it's just as likely to put Mrs.W off sailing, if she's not practised at such things, as it is to persuade her of the merits of getting a boat. )
Mrs W although not knowing how to tie a bowline and has the annoying habit of winding a mooring line rounda cleat just loves sailing
KevinV
12 Oct 2021
going to investigate possibilities quite a few boats in Galicia that can be chartered by the day
Seems eminently sensible to me - especially if you find a boat you like that is available regularly. All the pleasure of getting out there, easy to upgrade/ downsize, no capital outlay, no maintenance. In your esteemed case not having to make a final decision has to count as a plus too, and the benefit that if you find you really can't do it anymore there's nothing lost.
Having to take your gear/ supplies to the boat every time is a drawback, but you'd soon get the hang of the logistics. I do think it's vastly preferable to have the same boat every time - much easier on the brain if muscle memory can do most of the work.
Bouba
6 Sep 2016
SoF
So you have halved the cost to €100 by sharing with another couple...good idea.
If you want to halve the cost again....I suggest charging Mrs Wansworth half🤔😳👍
shan
14 Apr 2014
East Algarve
I think it's a good way for Wansie to get off his sofa and dip his toe back into sailing.
