peterb
The latest YM has an article relating to the accuracy of charts. It suggests that the errors may be due to three major factors:
1 Change of chart datum
2 Old surveys using leadlines rather than sonar (particularly sidescan sonar)
3 Old surveys in areas subject to rapid change.
I suspect that factors 1 and 2 are being taken care of already. As each edition is published the datum is being changed to WGS 84, and any new survey is likely to use modern equipment. But I am more worried about factor 3.
There was a time when virtually all survey work was carried out by the navy. Nowadays, though, much of the inshore survey work (i.e. those areas where many small boats sail) is done by harbour authorities. For instance, most of the surveying in the Thames Estuary is done by the PLA. The problem with this is that the main interest of harbour authorities lies in the shipping channels; banks between the channels are of interest only in so far as they act as limits to the channels. But small craft regularly sail across these banks, and sometimes their safety may depend on the accuracy with which they are charted.
Now I would quite enjoy going out sometimes and doing a little survey work. But would the Admiralty Hydrographic Department accept the results of my survey? Having talked to them at various boat shows, the answer apparently is no, because they can't trust the accuracy of my survey. Now they are probably right in that, but at the moment I know several places in the Thames Estuary where the charted depth is wrong by a metre or more, so I can't trust the Admiralty's charts, either.
The real point of this post is to wonder whether other small boat sailors might also have an interest in surveys of their areas. Clearly some do, because of the regular surveys of entrances such as the Deben and Ore. But what might be required for such small boat survey work to be fed into formal charts? Could there be a minimum standard of equipment, for instance, though almost any modern GPS and echo sounder will give the depth to within 0.2 m at a position known to within 10 m? Could there be a standardised format for submitting the results of such surveys? Is there scope for some organisation (clubs? RYA? CA?) to talk to the Admiralty so that a possible cheap source of reasonably accurate data can be made available to a wider audience?
Is anyone interested?
