ghostlymoron
My charging system comprises:- alternator, diode splitter, two seperate battery isolators and two battery banks. The system as currently (sic) wired feeds current from the diodes to the output side of the battery isolators meaning that the domestic battery bank is only charged if it happens to be turned on. This has caught me out in the past. Would it make more sense to put the feed from the diodes onto the 'battery' side of the switches so that both battery banks are charged regardless of the position of the switches. I am also considering fitting a VSR in place of the diodes as this will allow me to get much more charge into the batteries without the fiddle of soldering conections to the alternator if I used an alternator regulator.
