cindersailor
I recently bought a Standard Horizon HX260 hand-held VHF. Quite impressed with it so far, but have yet to test it very extensively. I noticed that on charging the battery it became quite hot, much more so than I am used to with mobile phones etc. The battery is 7.2 V and the charger says its output is 12 V, however when I measured it it was almost 16 V which will probably explain the heating. If I use an alternative charger which does measure as giving 12 V there is no heating at all. Although the charger was supplied with the VHF, I do not think it is the normal one as it is one which is used with a 12 V DC charging lead which is useful as I can use it to charge on the boat. Being curious I also checked the output of my nominally 14.4 V drill charger and found that it gives 20 V!
A couple of questions:
1. Is it normal for mains chargers to to have voltages way above their rating, or is what I am finding because I am testing them "off load"?
2. Has anyone else experienced this type of heating and am I doing the battery damage as I am assuming?
