Sailorsam101
Got an issue with charging on my port engine...AD41P-A.
The stb engine is showing 13volts while running and has the standard 60A alternator.
The port engine is showing 12.9 volts while running and has a 130A alternator fitted.
All of the boats domestic 12v systems run from the port engine and it's two batteries.
Always starts and not seen any issue other than the volt meter a bit low. Is this really an issue or is it lower due to the extra drain?
