Cardo
Apologies if this is a daft question, but a quick search hasn't provided an answer!
If one needs to charge the batteries using the engine alternator (say when anchored for an extended period and batteries need a little extra juice) would you run the engine and leave it idling or up the revs whilst leaving it in neutral?
When I leave the engine in idle, the alternator doesn't seem to provide much amperage to the house batteries (just looking at the little ammeter on the panel) however when I up the revs, I start seeing a good 5 to 10 amps flowing into the batteries (depending on what is on and using power at the time).
So if I was sitting on the hook and needed to juice up the batteries by running the engine for an hour or so, what should I do?
