Amulet
I have never had a good grasp of how this all works.
I have a wee Farymann diesel engine with an alternator built into its flywheel, a regulator on the back, and a cable loom of incomprehensibility back to my batteries warning lights etc.
I use the engine very little (sail everywhere), and I have trouble keeping enough charge in my batteries.
I would like to stuff more charge into them when they are really low and wondered about (a) faffing with the incomprehensible regulator, maybe replacing it with something more intelligent, or (b) putting another alternator on the prop shaft with its own system to beef things up.
If I went for (b) would it cause any problems to connect two different charging systems with their own regulators to the same battery bank? (I'd like to be able to switch it between banks and so they are both likely to end up on the same one at some point.) I'd have thought that all that could happen is that the regulator on whichever alternator was delivering the lowest voltage would simply shut it down and let the other do the work.
Or is this all madness?
