Daydream believer
This is exactly what the suppliers of my batteries told me and my domestic AGMs have lasted 5 years so far.I'm not sure this is quite right and it is certainly out of step with Victron and Mastervolt.
First, no I don't think one does need 14.8V to charge, rather that is around the top end for a fast charge in normal temperatures of 25C. In warmer conditions, and certainly proximate to a hot engine installation, this is too high. The normal AGM charging voltage is 14.2-14.6V.
Similarly, the recommended range for float voltage is 13.5-13.8V and 13.65V just happens to be the mean.
Finally, for long-term storage (i.e. any extended period of time), the float voltage should be somewhat reduced: 13.2-13.5V is recommended. The same applies to most lead batteries.
however the suppliers of my Red Flash battery ( Tanyia i think) told me that was OK for Red Flash and the first one failed after 18 months. (12 month warranty?) I checked with them again and i have now bought another so i will see how that goes
i think one needs to look at the specs from the actual manufacturer rather than supplier as they do vary a little between batteries
