mrplastic
Hi all,
I will shortly be running the cables to my new bowthruster. The question I have regards charging via the engine. The battery ( a 100ah gel) is about a foot from the thruster motor and I'll be running a couple of 16mm cables around 8 metres in length to the battery for charging.
The current set up is 1 engine battery, 1 domestic battery and another for the windlass. The latter two are wired in parallel and charged together with the engine battery via a split diode relay.
Can I remove the existing 2 battery split diode and simply replace it with a 3 battery unit and run my charging cable from there or is more complicated than that?
As always, useful advice is much appreciated!
