michaelmccann
I have a gearbox problem and am trying to remove it.I have taken out 6 no bolts but it is not splitting from the bell housing.I then tried to remove the bell housing.I removed all the bolts from the bell housing.The joint between the bellhousing and the engine block split by about 5mm at the top but it will not come off.The gearbox was losing oil and may have seized.I think the seal between the gearbox and the bell housing might be defective as there were traces of oil in the bell housing.The gearbox is Borg Warner AS-11-72CR.
Would appreciate any suggestions.The obvious one is to get a professional!!!
Regards Mick McCann
Regards Mick McCann
