Deefor
On my Honda BF20, I've always changed the lower leg gear case oil with the boat/engine out of water. Therefore the engine is always vertical and the fill level is always in the horizontal plane.
However, if I intend to do the gear oil change with the engine in the water, I'll have to tilt the engine out of the water to around 45 degrees to get to the drain/fill plug. In this orientation, how would I get an accurate level reading when I refill from the bottom hole?
