EdEssery
My boat came out of the water today and I changed the oil in the sail drive leg.
Draining it through the sump plug on the bottom of the leg was easy. Refilling it with oil afterwards was NOT!
The filler is at the back of the engine and accessed, on my boat, through a small circular hatch. As if it getting to it wasn't difficult enough - when I poured the oil into the filler it backed up, ran down the engine into the bilge. It seems you have to pour the oil in very slowly - I've no idea why.
I wasted about a litre and half of oil before I came up with a solution. I bought a metre length of 3/8" hose and a small funnel. I fitted end one of the hose tightly over the end of the filter funnel and stuffed the other end through the hatch in the aft cabin and down the hole for the dipstick (into which it fitted snugly). I then sat down in the aft cabin and slowly poured the oil out of a measuring jug into the filter funnel. Voila! No mess in the end but another piece of kit to keep on the boat.
If you've got a Volvo sail drive - I suggest you try this approach unless *you* know a better way?!
Ed
Ed
