ghostlymoron
After a bit of a struggle and dropping my glasses into the bilge, I managed to remove the impeller from my water pump. To my surprise it was attached to the shaft as shown in the first picture.
I was expecting just the impeller to come out but it has a screw through it which goes through a hole in the shaft. So obviously it can't be removed from the shaft until both are removed. Previous pumps I've had have had a flat on the shaft (and the impeller) so it just pulls off, leaving the shaft in place as shown on the extract from the manual shown below. You'll have to click on the link.
http://www.keepturningleft.co.uk/wp...images/Mirror-Offshore-U-MD1-manual09_jpg.jpg
Is this right? and do I just have to put a new impeller on the shaft and re-insert it?
