superheat6k
I recall this was a bloody awful job on my Turbo 36, well I can assure things are no simpler on a Corvette 32 either.
Working hunched up through a small opening at the back of each engine knelt on the floor of the aft cabin and hanging into the bilge, to find most of the coupling assembly bolts (R&D Coupling) rusted and very very tight, the cutless bearings swollen and very stiff on the shaft at both upper and lower, extremely tight props, encrusted Allen bolts on the gator rope cutters, and one rounded cutless grub screw.
So far after ~ 8 hours attention I have: removed the props - 10 tonne hydraulic puller; removed the gland follower studs - locknuts (3), hacksaw blade and handle (1); R&D coupling bolts - impact wrench 14 (30 minutes), Dremel 2 (2 hours); output coupling retaining bolts - 3/4" drive socket with handle extension bars and a Houdini impression inside the engine bay !
To do:
Remove output couplings - puller, possibly hydraulic, to remove the couplings from their tapers (or else a hacksaw and two new shafts !!!).
Pull out shafts - fairy liquid and elbow grease
Pull out cutless bearings - purpose made puller
Remove the stuffing box seals and mount rubber tubes.
Then the simpler task of installing the new cutless bearings and PSS seals can commence. Still should be done by February.
To do:
