FairweatherDave
With the first time of winterizing my Beta 25 engine I thought I should explore the engine a bit and change the pencil anode. As part of winterizing you suck up antifreeze mix through the sea water part of the cooling system and I did this. Then I have changed the pencil anode which was well wasted. But obviously the anode is not going into a seawater situation until I launch the boat next season. So does the six month rule apply from now or when back in the water? When does the clock start? (I do know they are not expensive, particularly when compared to the engine, and I do know I need to do more serious reading about anode protection). And I did do the heat exchanger rodding job while I was there. Thanks for any replies.
