Ian_Edwards
I've just been checking over the steering gear.
The boat has twin wheels and an autopilot.
The port wheel has a heavy chain driving a cog, which is meshed into a quadrant mounted on the rudder shaft, it's a bit like a quarter of a differential.
The starboard wheel is the same and the two quadrants are connected by a massive tie bar.
The port wheel is also connected to a Lewmar Manba type 2 rotary drive, so the rotary drive moves the wheel which the moves the rudders.
There are 3 chains, each about 1m long, and they are all quite slack, if you move one wheel, you need to move it by about 5 degrees before the other wheel moves.
The chains needs to be tightened and each one has a bottle screw (turnbuckel?), so it's easy to do.
Questions, how tight should the chains be?
Is there a rule of thumb?
I'd like to get rid of the slack, but don't want to make it too tight and cause excessive wear.
