pmagowan
How big are yours!
I have been looking at chain plates recently and wondering about the best designs. It seems that a lot of the modern production boats have the shrouds coming down well inside the hull and terminating on the deck. The chain plates are therefore simply attached to the deck. They are normally stainless steel from what I can see. On my boat, which is only 28 feet, they are simply a heavy flat plate that runs down the inside of the hull and are through bolted to the hull. They are also stainless steel.
I have seen, in some design forums, the use of carbon fibre to make chain plates. In this method the carbon fibre is part of an epoxy composite. Where it breaks through the deck it is made into a loop that looks like a carbon fibre rope (coated in epoxy). Under the deck the fibres are splayed out and epoxied to the hull so that the load is widely distributed.
Since these are a big factor in the strength of the rig I am interested in what you have on your boat or any knowledge you might have on the subject. I am always considering things with regards to a potential circa 40 foot blue water cruiser.
