BERT T
Crosby C Links are available from http://www.tecni-lift.co.uk/Crosby-10mm-G335-Chain-Missing-Link-1250-kgs-WLL-221-013-156
10mm £8.37 + vat if anyone is interested.
Jimmy Green sell grade 70 with an oversize link on one end.
There is a lot of misinformation on G70. It is made to exactly the same 'brittleness' spec as G30 and G43. ...
...However G70 is currently one use only, once the gal has gone you have worthless scrap - so long term its not a good buy (if you think chain should last for ever). Also if you change to G70, from a larger less strong chain - then you need a new gypsy - and they are not cheap.
Curiosity question then: are the G30/40 chains also not regalvanisable ? If not whats the materials difference that makes this so ... TiA
Its not that I think chain should last for ever, though the Wedge website does use an example of a user that has had 4 or 5 regalv cycles, but the quality of a regalv seems to mean that the protection gives, anecdotally, up to 10 years against about 3 from the manufacturers galv process
