Nick_H
I have two centrifugal pumps feeding raw water cooling circuits, one for the air-con, the other for the gyro. One is US built (Oberdorfer pump with Dayton motor), the other Italian (CEM pump and motor), but both look similar and are 220-240V 50 hz, 1/2hp, 2,800 rpm, continuous duty, with bronze pump body and impeller, and 316 shaft. Does that mean they're definitely interchangeable, or are there any other factors that also need to be the same?
I want to carry spares as life on board is far less comfortable without the gyro and air-con, and i'm thinking I only need one.
Also, the gyro cooling pump has failed twice in 5 years, whereas the air-con pump is still going strong after 12 years. The gyro eats pencil anodes, so i'm wondering if the pumps are being damaged by electrolytic corrosion. The installer has recommended a fresh water flush system is added to the cooling loop, which sounds a good idea. Am I right in thinking that flushing will stop any electrolytic action whilst the gyro is not in use?
Finally, any recommendations for the best value pump manufacturer?
