dylanwinter
Mines a Pageant which is basically Centaur minus 3'
I lifted her this Summer and this is what it looked like (just after pressure hose and prior to AF)
Don't be put off by paint flaking from the pods - this always happens and whether it's flex or pressure hose angle or just the Sea- it doesn't matter one way or the other. In your Centaur the Keel weakness will present itself on the inside of the layup.
I would say that the keels "let" about a pint or two of water a season. Which seems fine. I re-siko them every time I do a lift. Sometimes I even go as far as raking out some of the old sealant before injecting fresh but only if I'm feeling extravagant! For the last ten years I've been pondering a keel drop to do the thing properly but, you know, too busy sailing.
However, I do keep an eye on the rust around the bolts - there's a bit on each - but nothing to get in a twist about. The day she starts weeping pints in a day will be the day she comes ashore for the keel drop.
And that doesn't have to be the end of the world either.
so....
regarding the Dinorwic centaur....
it is full of water but none is leaking via the keels apparently
so is that a good thing then? I mean the lack of weeping?
and what happens if the bulkhead has rot
snaps here
http://www.keepturningleft.co.uk/wp-content/uploads/IMAG1310.jpg
http://www.keepturningleft.co.uk/scuttlebutt/port-dinorwic-centaur/
