ianj99
Good result.
Do let us know if they offer their explanation for the failure.
I will post an update when the replacement arrives on friday.
Even if this is identical to the original, I still don't understand why the holes need to be so close to the edge when it is quite possible to move them outwards by 1 or 2mm.
The other alternative would be to increase the depth of the holes by 5mm and lengthen the bolts by about 8mm, and also drill out the thread for the first 5mm.
(The supplied bolts stop 5mm short of the bottom of the hole).
This would avoid the stress at the top of the bolt hole where the edge distance is least.
The bolt holes are 25mm deep, the bolts supplied have 18mm of thread below the flange. The coupling bore is 40mm deep. Therefore I can see no reason why the holes can't be 30mm deep, the bolt 25mm long, and the top 5mm of the hole counterbored to remove the thread and the holes moved outwards by 2mm.
I am tempted to drill 6 new holes tapped at 6mm in the broken coupling between the existing 8mm ones and keep it as a spare.
