Westering
New Member
Hi!
Sovereign 32 - new Yanmar 40HP replaces Mercedes 42HP (overkill I know but the engine was a bargain). New matched 2-bladed prop replaced the other 2 blader. Result: cavitaion with noise and vibration in ahead.
Local advice was to fair the leading-edge of the rudder, which I have done with some improvement but not much. (The keel is very long fin with skeg - almost long keeled really - small cut-out for prop.
An acquaintance with same boat though slightly different rudder had a 30HP engine but fitted a 3-blader - he has no problems. Should I do the same? - though I'm reluctant to accept the drag as I race a bit and have a very good centreing prop brake! The noise is annoying though and I worry about the vibration causing wear somewhere(?) and we are going to do some extended cruising this summer...
Suggestions wlecome - though not too technical please or you will lose me!
