Kelpie
Changed my engine's CAV filter the other day and I'm really struggling to get the new one to seal. I've tried a different filter just in case, but no luck there either. There were two different O-rings supplied so I've tried swapping them over and even tried doing without them. I've also cranked up the bolt as tight as I dare, but still the diesel weeps out. It's a problem because as idle the engine is drawing in air and this causes it to stall after about ten minutes of idling- made for a very interesting approach to a pontoon the other day!
The weep is coming from the joint between the bottom of the filter and the (metal) bowl. I can't see any deformities, damage, or debris in there.
The filters are Delphi 296. Maybe I should try a different brand?
