geem
I owned a Prout Snowgoose 37 for 11 years and dont view those drive legs in quite the same way as you. Yes they are agricultural but like anything in a marine environment, they need to be maintained. When we bought our Prout she was in pretty poor condition, including the drive leg. We stripped the leg and refurbished it including shimming bearings etc. With regular oil changes and greasing I came to really appreciate the benefits of that leg. With a little practise we could manoeuvre that Prout in and out of marine berths in strong winds to the suprise on many. The benifits in an old catamaran design like the Prout of minimising weight by only having a single engine cant be over emphasised. I suspect 90% of those cats spend their life overloaded and performance suffers horribly.I have owned both. Frankly the sillette legs are a bunch of **** engineering wise. They are always in need of service regarding pivot points and locking mechanism and are very very noisy. The only advantage of the damn things is that you can raise them when not sailing and if you get a rope around the prop. However, be warned that I once got a rope around a prop and it tore the leg completely off its yoke. The castings are very poor and pourus and break easily! Twin engines are far better but like all sail drives you need to be assured that the rubber gaskets are in good condition and there is no water getting in the engine bay because it can corrode the sump and cause big oil leaks. For manouvering the twin engine configuration is also far better and you dont need contra rotating props with them that far apart. The ideal set up IMHO is twin engines with brunton autoprops. Perfect!!
Knowing what I know now, I wouldnt consider buying a Prout Snowgoose with twin engines unless I was happy with a motorsailer. They are simply not large enough, in my opinion, to bear the weight of twin engines in such a small vessel.
I suspect we had the fastest Prout Snowgoose afloat with her extra tall rig and lightened set up.
