DarDublin
Hi guys!
Hello everyone, as my first post I will start with the problems haha. So I have princess boat with 2 CAT3116 engines:
STB engine doesn't go over 1200 RPM once in the gear - Revs no problem above that when in neutral.
Port engine is the same , doesn't go over 1200 RPM , except when it reached that RPM the RPM actually drops. - Revs no problem above this mark in neutral.
I have warning light/sound on when I start Port engine. But I don't think it is related , because there is no ECU in this engine I believe. Oil pressure is good and the temperature good - I have gauges to show that. I obviously need to find why the warning sounder does not stop when I start the engine.
Any thoughts? I know there could be plenty of things but where is the best place to start ?
Thank you for any input!
Dar
Dar
