Swift28
Had boat few years now , been doing most of the servicing work myself , starboard engine just starting to creep up in temp above other lately ,nothing bad and no alarms as of yet, have pulled exhaust water hose off and can see bottom of tubes in heat exchanger starting to gum up a bit now where water been sitting , want to take the end caps off and rod them through and then run some rydlme through complete system after, just to give them good clean up ,
Anyway trying to find out info for the C9s seems hard, not too much info out there, have the basic service mantenance manual but pretty usesless really, been reading up online as you do and now worried about the aftercoolers , am planning on stripping off , cleaning up but do they really need replacing? all i can see is various people saying CAT reccomends replacing all aftercoolers every 6 years ,
The internal core unit is an eye watering ( £6,618.66 GBP - CORE AS-AFTERCOOLER - Add To Cart x 1 ) Finning poole
Is this just them being over cautious because of what happened on CAT earlier models?
Engines done around 680hrs serial no C9B00109 & C9B00129 , anyone know much about these , good ,bad points to look out for
Im going to replace the coolant with CAT ELC , do they really take 47 Litres per engine , sounds alot thats all , again service manual left blank on this exact figure , that was from googling about
Any info on these engines and help be great , very little out there it seems , must be that sort of year / model
Cheers
Cheers
