John100156
Hi
I would like to flush my Cats next time out on the boat, I have a couple of gallons of Rydelyme in the garage. I was thinking of back-flushing as the following sequence:
.1 Isolate SW sea cock and insert pipe connector to lid with a pipe outlet to a large bucket
.2 Remove impeller and anodes
.3 Remove the engine hose entering the exhaust elbow and connect hose to solid pipe from pump flow (hence reverse flow through engine)
.4 Install suction hose from the pump to suck solution from the large bucket allowing capacity for initial foaming
.5 Isolate valves to stern gland water feeds
.6 Circulate over night
.7 Install new impeller and anodes
Anyone done this to 3126's before? if so is the above acceptable, any advice welcome....!
Was thinking 50/50 mix of RL/Water?
