Carpet
Silvercloud
10 May 2020
I want to replace the PINK :mad: carpet in both cabins on my T36 and would like some advice on the best type of carpet to use please.
The current carpet seems to be foam backed.
I replaced all of the old, original, beige carpet in my Antares last year - I went to a carpet supplier/fitter in Oban who also do boats, and what I ended up buying was a rubber backed commercial carpet (not beige), which has been ideal. They did have a few different types they said would suit, so your best bet would probably be to speak to a similar business near where your boat is kept.
........... what I ended up buying was a rubber backed commercial carpet (not beige), which has been ideal. They did have a few different types they said would suit, so your best bet would probably be to speak to a similar business near where your boat is kept.
ditto. I said mine had to be kid proof. So far so good and surprisingly comfortable to walk on as well. I was so impressed I had him make up some for the cockpit fixed with carpet studs.
Good point, we have inherited a wool carpet with ours, sheds badly, fills up the vacuum cleaner and leaves dust on all horizontal surfaces.
I did use a carpet with a hemp backing once. Got damp, smelt and then rotted in a season. I like the inside of the boat dry but when the weather is inclement and oilskins wet water does get down below.
Rubber back Bathroom carpet .............. I used it on my Alacrity .. and also on my Snapdragon 23 ....
Foam backed - was on the Snap 23 when I bought it but ended up with foam breaking up and clean-up !
Present boat had Hessian backed ... which of course was great - but hessian rotted and ended up as dust ...
I'm just waiting for the fwd cabin section to go as well - then I'm off to Carpet shop to buy a roll of Bathroom carpet ...
I have also looked at non-slip vinyl as used for Kitchens / Bathrooms ... the thicker softer kind ... then its waterproof ... kind to the feet and non-slip .. easy to clean.
In both of ours we fitted Flotex carpet flooring and after 7 & 9 years respectively of living aboard, both were still immaculate; when they get grubby just detergent and a scrubbing brush or steam/jet-wash clean on the pontoon. Not a cheap product, but offset by being very easy to self-fit, with no need for edge treatments and happily 'sets' to the shape of any sloping bits of floor
