Koeketiene
Title says it all: which is more practical/easily obtained in the Caribbean - propane or buthane?
Whatever you can get, it can be a mixture of both. Best to have propane bottles probably.Title says it all: which is more practical/easily obtained in the Caribbean - propane or buthane?
The French islands can be difficult about strange bottles. IE Anything not Camping Gaz.
Looks like I'll be refilling in the French islands then.
...Butane and Propane use the same burners, and the regulator pressures are the same....
True, but they are cheap at less than a tenner each, so that's what we bought. With the changeover valve as well, it is dead easy.but only if you have a 30mb regulator. Earlier installations may have a 37mb or 28mb regulator designed for the individual gases, propane and butane respectively (iirc)
Care to tell us how you make the copy?USA stations will often refuse to fill any non US certified bottles. Some cruisers have been known to add there own certification copying it from a US bottle.
