Carbon Monoxide?
Giblets
5 Mar 2006
Surrey
For a correctly burning gas flame very little (if any) CO is produced. Only incorrect combustion caused by damaged, worn or dirty burners or, more importantly, lack of oxygen (ventilation) produces dangerous amounts of CO.
Seven Spades
30 Aug 2003
Surrey
That's the answer I was looking for thanks.
prv
29 Nov 2009
Southampton
Why don't we all die of carbon monoxide poisoning when we use our gas stoves on board?
Because a correctly-adjusted clean-burning flame produces little or no carbon monoxide in the first place, just carbon dioxide and water.
That plus ventilation, which ensures the burn remains clean (sufficient oxygen) and allows any CO that is produced to escape.
Iliade
27 Apr 2005
Shoreham - up the river without a paddle.
www.airworks.co.uk
We have a CO detector. The hob burners leave it at zero. The grill burner has the faintest of yellow tips to the flames and will send the CO detector racing up. I never use the grill long enough to actually trigger an alarm, but it is a real warning that I need to fix it.
Sooner or later you will either use the cooker to heat the boat or nod off while cooking. Fit a detector and if it shows anything above zero, investigate.
Giblets
5 Mar 2006
Surrey
Out of interest the worst section of the cooker for producing CO is normally the grille. Something to think about when making one's morning toast!!!!
alant
30 May 2001
UK - Solent region
Thats not right. It only needs 100ppm to be dangerous to human health. It apparently prevents the blood passing oxygen on to your body which is why CO poisoning is so difficult to treat.
The CO, replaces any oxygen in your haemoglobin, forming a carboxyl haemoglobin, which gives you that nice red face.
I used to work in a place that used it as a process gas, with frequent leaks. Anyone 'gased' in those days, was supported by 2 of his mates & walked around the yard in an attempt to rid the bloodstream of the stuff.
born2sail61
18 Oct 2013
Harwich
have had a minor case of carbon monoxide,domestic not marine,and it is not pleasant.happily I survived with some of my faculties intact.not an experience I wish to repeat so an alarm is always a priority
