VicS
I ask once again, why is Yngmar in post #11 getting off scot-free when this was his train of thought rather than mine? He even specifically asked for an opinion.
Richard
Polly's Kettle replied to that.
Richard
The same Polly's Kettle who has bought 4 detectors the same as mine?
Richard
I fully agree with the need for gas alarms and smoke alarms on all boats but in many cases I think the need for a CO alarm may be overstated. There have been some tragic accidents on mostly inland waters and relating to gas heaters but as far as I can tell none were related to diesel engines, diesel heaters found on most sea going yachts. QUOTE]
We have on record two fatalities from oil fuelled kit - heater and generator. Most inland incidents are from solid fuel stoves and petrol engine exhausts including inboard engines, outboard motors and portable generators.
Other sources include paraffin heaters and included in the solid fuel stove list was a charcoal heater on a motor sailer.
Gas appliances including fridges and ovens have also been killers.
Any carbon-based fuel burning appliance can produce CO. As it was said 'up-thread' an alarm in not the primary defence, preventing CO is. But an alarms is the "just-in-case backstop" that may stop a critical event becoming a fatal event. We have some simple CO alarm advice from the manufacturers association CoGDEM here www.boatsafetyscheme.org/stay-safe/carbon-monoxide-(co)/co-alarms-save-lives/
I only use the CO detector when I use the generator which means that the engines are not running so there is no vibration. I place it in the cabin nearest to the generator which is as dry as my house. It's a solid state device (from Argos) so I can't see an issue as it can't be that fragile.
Richard
Alarms tested to BS EN 50291-2; take account of the marine environment such as wider temperature variations, greater humidity levels, chemical environments, and vibrations and jolts. But as CoGDEM say and we restate if you have an alarm tested to BS EN 50291 use it happily and replace it at the end of its life with a unit tested to BS EN 50291-2; By the pressing the test button also tests the sensors and circuits, not just the battery. Perhaps we can orchestrate a unified YBW beeep?![]()
My Argos detector is a Kiddie one coded EN50291-1 : 2010 and has a section entitled:
2. Further information for Caravan and Boat Owners
The following can lead to carbon monoxide being produced;
• Using LPG cooking appliances for space heang
• Leaving LPG appliances on overnight
• Barbecue’s within the boat cabin or near a caravan door (e.g. under an awning)
To be safe, know the possible sources of CO in your home.
........ so it's good news that we are all OK with detectors with that code, which is perhaps all of them?
So Yngmar was right and the panic is over, thank you.
Richard
No . Only EN 50291-2:2010 ones are suitable for boats and caravans . EN 50291-1:2010 is the spec for home use only
That's the point of my post at #3, which is confirmed above by BSS Office.
So the manual written by Kiddie for their 5CO model is wrong?
Richard
I did not see any statement in the manual for the 5CO that it is suitable for use in boats and caravans !
ITYWF the advice for boat a caravan owners is just that , no more. I suspect the same appears in all their CO monitor manuals. Certainly in those I have looked at
A little more info about these specs at http://www.safelincs.co.uk/british-standards-for-co-alarms/
If you look at Kidde's data sheet for the 5CO you will find no mention of boats or caravans. If OTOH you look at the datasheet for the 7CO and 7DCO you will find that is specifically says "BSI certified to EN52091 Part 1 and Part 2 (Caravans and Boats)" (qv)
ITYWF that the section to which you refer has been replaced in the latest manual for the 5CO ( http://www.kiddesafetyeurope.co.uk/D...G_5CO_2015.pdf ) by a similar section in which there is no reference to boats or caravans. Presumably ths has been done to avoid the confusion so obviously caused by including information for boat and caravan owners in a manual for a piece of equipment which is not BSI certified for use in boats and caravans.My opinion is that the section on Caravans and Boats is included in the manual because Kiddie believe that their 5CO monitor, and possibly all their current models, (although I haven't checked all the others as I'm primarily interested in the one I own) is/are fully suitable for general use in caravans and boats
Richard
I am afraid your "opinion" is just that your misguided opinion.
A month isn't a "dead thread" right? I can revive it?
Last weekend I fixed my heating (hurrah!) but was a bit concerned about CO: it's a 25 year old Ardic and was smelling a bit dieselly the first day, so I googled this thread, then ordered a BS50291-2:2010 compliant detector which turned up today (Fireangel CO-9D) Thankfully it's sitting at 0ppm as the newfound experience of warmth floats around me BUT...the instructions have a big "not suitable for boats" ( well, actually a pictures of a house, a caravan, a truck and a sailing boat and the sailing boat has a big X over it). No explanation.
Here's the recommendations I just turned up from the boat safety scheme:
http://www.boatsafetyscheme.org/media/264586/CoGDEM-CO-alarms-List-Feb-2015.pdf
They say BS50291-2 *AND* marked as suitable for boats (there's some recommendations in the link above). I'm not going to chuck this one out and get another one but just a heads up for folks who do want to get a pukka "boat" detector...
Very confusing!
If it complies with EN 50291-2:2010 then it should be suitable for boats !
Incidentally its the same model as I have at home. There is no mention of suitability or otherwise for caravans , RVs or boats in my instruction book. Only EN50291:2001 is mentioned as it pre-dates the publication of part 2 I am sure.. Soon be due for replacement!
The digital display seemed like a good idea at the time but wont bother with it next time round
Some alarms went to market being tested for the recreational vehicle element of EN 50291-2:2010 without being tested for the boat elements.
If you can market things without completely testing them to the standard, that will tend to undermine the standard. Not to mention create confusion, which is what any standard is intended to prevent. Certainly I would feel pretty confused if I bought an alarm marked with the standard whose manuals said it should not be used for things certified by the standard.
