[33964]
My "new" boat, an Ovni, has aluminium water tanks.
I've read that the chlorine in normal tap water (e.g. in marinas) causes a reaction with the aluminium.
Am thinking about a way to filter the incoming water when I fill the tanks (approx 600 litres total).
Anyone done similar? What did you use?
High flow rate would be needed I guess.
Quick research so far suggests 20 inch rather than 10 inch filters, along with some sort of pre-filter pump to get the flow rate.
I may have space to permanently install it, or a portable set up that can be put on deck and connected up with the input via a normal hose connector could be better.
Thoughts anyone?
Also, what sort of life span would the filters have?
Thoughts anyone?
