Jcorstorphine
I have been rebuilding my Ford diesel engine and have at last got all of the Torque to Yield bolts with the exception of the M20 x 1.5 pitch on the crankshaft pulley. This bolt is torqued to 20 Nm then tightened through 120 degrees but try as I might, I cannot get anywhere near the 120 degrees. Best I can get is about 50 degrees at which point I am pulling 220 Nm on the torque wrench.
Is it possible that as the bolt has been used before, I can no longer stretch it to the desired amount as set out in the manual.
My concern is that the “main crankshaft timing gear” is only secured by the locking force produced by the bolt with only a 3 mm seloc pin to provide location. If the bolt were to slacken, the timing gear may slip causing untold damage to the engine.
One thought was to use a Schnorr or Bellvile washer to provide a permanent tension on the bolt. The washer I am looking at can produce 20,000 lbs of tension in the a 20 mm bolt when fully compressed but will this be similar to the tensile force created by stretching a 20 mm x 1.5 mm pitch bolt by 1/3 of a turn i.e. equal to 0.5 mm stretch.
I am reluactant to use Loctite in case i need to get the bolt off again to change the crankshaft seal as I nearly gave myself a hernia getting the dam thing off in the first place.
All suggestions or comments gratelfully received.
John
John
